February 10, 201313 yr Hey guys. Think this is the best suited forum as I beleive any bikes run the Dallorto PHBL 26 carb? My choke flip switch is broke. I have undone the screw.. It pulls about about 5mm, clears the top seal and it won't come out any further? Is there anything else I have to remove to get it out? Number 32 here.. And this is what it looks like once removed.. Many thanks. Jamie
February 10, 201313 yr Agreed, carb cleaner and soak overnight Nothing else will affect green gas mung Probably the reason the flipper got broke in the first place is that it was sticky
February 10, 201313 yr Author So it should just pull out then? I know I can put a little force behind it if so. Will get the cleaner in there
