Evo Carb Jets
betarick
Huh, crank bearings toast
Well using one base gasket does two things, increases the compression by not only moving the head closer to the piston but also closing the exhaust port earlier
Lowering the exhaust port would affect power on its own, maybe will have more bottom and midrange this way regardless of engine work
