Ossa: Would You Do It Again?
Ossa 2011 and trying this years ssdt on it. No mods at all except a low fuel light and I may change the tyres, oil and air filter. Runs even better after my dealer raised the idle but uses approx 30% more fuel with a new map. On the plus side it has even more torque and will go up anything.
  • Replies 49
  • Views 21.6k
Most Popular Posts
  • canada280i
    canada280i
    JSP, you're a Yorkshireman......no one wants to buy a kidney that has had that much beer flushed through it!
  • canada280i
    canada280i
    Ha!.....sorry Dabster but you are absolutely incorrect! I did buy my new bike bike from the importer, as I did my first Tr280i, but that is as far as my connection to Borus goes. So for everyone els
  • Certainly have some constructive post at times dabster, but Its a bit sad that your so quick to stick in your misinformation and unfounded, smart aleck comments on a subject that has little relevance
Had a 2012 great bike but had a gearbox made of choclate, 2 gear selector shafts in 6 mths :wall:
Sold it and lost over 2.5k in my short ownership, now got a 2013 Sherco and very happy.
MOST CERTIANLY , I'd say the guys girls ;) having a hard time starting them ,need to learn how to kick over a bike.
I let EVERYBODY who wants, ride mine , so far ONLY ONE said he preferred his bike.
i prefer my bike
And Me
Me also
Piece os pi@@ to start.
Just picked a used example up.. Got it home, 2nd kick it started.. Don't know what all the fuss is about...
  • 1 month later...
My father and I had more trouble starting ours than probably anyone on here. Once we got the 12v battery packs hooked up we've been happy as larry.
Have ridden everything else on the market and the only other bike I really like is the Montesa. I'm sure I'd get used to any of the others but the Ossa just feel really nice to me soon as I jumped on it.
good for you mate you at the trial on sunday its at mickerdale
Just got a factory r 300i, first trial tomorrow, looking forward to seeing how it handles
Looking forward to your impressions, what grade do you ride.
  • 4 weeks later...
Hi,
This thread makes interesting reading. I'm in the market for a new (or newer than what I have at the moment) bike and have been looking at the Ossa TR280i. At present I ride a Sherco and a guy in a club I ride for has a Ossa (2012 model I think) and a couple of weeks back I had a go on it, all I can say is wow! I've riden a few different bikes over the last month or so (2011 Beta, 2012 Factory Sherco, 2008 4RT and a few others) but to me the Ossa felt streets ahead so this made me investigate the bike further as I didn't really know too much about the bike other than it being an FI 2T.
So... after some more investigation it seems Ossa have really up'd the design & engineering behind a trials bike and kinda left a lot of the other manufactures bikes looking like dinosours. In my opinion there really has been some thought gone into the engine design. With traditional engine designs, changing crank bearings means the crank case has to be split exposing the gearbox and all the hassle of new crank case gasket, making sure its air tight etc and if you have a gearbox problem again the crank case has to be split removing the barrel, crank etc which means all new gaskets again.
With the Osaa it appears the gearbox comes out as a unit by removing the clutch cover, clutch and 5 bolts, take the front sprocket and gear lever off and the complete gear box assy taps out... fantastic, without even having to take the engine out of the frame. Same goes for the crank as the gearbox can be left alone and once the stator, barrel & piston is removed the crank can be extracted through the side of the engine case and there is a cutaway that the small end of the conrod slides through. Thats a really well thought out design.
Also the plastics seems really flexible so less chance of breaking mudguards when the envitable crash happens, fuel injection too, no more having carbs apart and fiddling around with jets and settings. 100+:1 fuel / oil mix! bit of a saving there. The bike I rode a couple of weeks back had a great feel to the suspension and the throttle / power was so smooth.
I know there have been a few issues with starting but this seems to have been sorted with the optional battery pack.
To be honest I'm not sure why they aren't more popular??? Answers on a postcard....
Cheers,
Gary.
Sorry steveo, I just saw your reply. I currently ride the junior line in Canada, although first time out I won my class for the first time and only dropped 3 marks for the whole event. Could have been luck, I like to think my confidence was up on the new bike, it ran perfectly and just felt right on the day, so much so that I will likely move up to intermediate level.
To sum up as follows:
Power - plenty of it, a little fierce at times, may benefit from a slow tube but will try it as-is at least one more time
Weight- bike felt nice and light and was easy to manouver
Starting- no issues, battery pack fitted so was easy on the legs all day
Overall fun factor- off the scale!
........and did I say it has a termignoni exhaust on it, apart from looking good it also sounds very nice!
I. Should start a "what did you do to your ossa today" thread, every day would start the same..."looked in awe at it before firing her up"
Hi,
Cheers,
Gary.
Tbh if you want one go for it. A 2012 in good condition sold for £2400 last week so don't pay over the odds.....
So no one is in any Doubt 280i is the importer of these bikes into Canada, I believe, so his views are not completely un biased.
