ikb Posted April 12, 2013 Share Posted April 12, 2013 Just wondering does the Ossa need a fast tick over like the 4rt? I quite fancy one but I like my bikes set to just tick over. Ian Quote Link to comment Share on other sites More sharing options...
canada280i Posted April 12, 2013 Share Posted April 12, 2013 No, tick over is generally set by the mapping software so your dealer should be able to set to your personal liking. For me, I like mine a little faster so that is how it is set Quote Link to comment Share on other sites More sharing options...
midlife Posted April 13, 2013 Share Posted April 13, 2013 You can adjust the tickover with the small screw on the side of throttle body. Quote Link to comment Share on other sites More sharing options...
borus Posted April 13, 2013 Share Posted April 13, 2013 is generally set to 1500 rpm, 50 to 100 either way is noticeable. cheers Quote Link to comment Share on other sites More sharing options...
picktas Posted January 13, 2014 Share Posted January 13, 2014 If you change the idle speed using the small screw on the throttle body - that is step No1. Step No2 is to reset the initial throttle position to the ECU, using the software and cable. If you don't complete step No2 then the fuel mix will be incorrect causing fouled plugs etc. 1 Quote Link to comment Share on other sites More sharing options...
steveo Posted January 13, 2014 Share Posted January 13, 2014 Just so you remember how important it is, what picktas has so righty pointed out,, IF YOU DONT do step No 2 with software after any changing of the idle speed no matter how minute you think you have done, your ECU is now confused and problems will follow..... Quote Link to comment Share on other sites More sharing options...
canada280i Posted January 13, 2014 Share Posted January 13, 2014 Or just get one of those btwice throttle bodies that have the idle screw built in, still need to have the tps set when you install but you can then adjust the idles anytime you want without further tps setting Quote Link to comment Share on other sites More sharing options...
