Sherco Clutch
lee
the new main bearings making the whine? did you use a dealer part becasue im sure the standard sherco bearings do, im sure some one will be able to shed the light-ask honda rs, ishy or jtt. :lol:
Make sure that you put everything together in the right order, If you have put something in the wrong place, eg. a washer then something could be rubbing, check the back of the clutch basket isnt touching the main drive gear or that the clutch isnt rubbing the clutch cover, etc
get the pump drive gear the plastic lined up properley on the crank drive gear,. becasue if not it could do what it did on mine the pin from the drive shaft come out and mangle all the drive gears :lol:
