Speed Nut Tip
charlie chitlins
That speed nut that holds the rear of the tank and the front of the fender...I always knock it off when putting it together and I figure if I keep squeezing it tight so it grips, it'll break.
I drilled a hole in the little tab on the frame that locates the speed nut, slipped the speed nut on the frame and put a piece of safety wire through the hole.
No more searching for the speed nut.
