August 27, 201313 yr Hello, not found anything by searching for an 80. Can someone recommend the best gearbox oil for a 2011 Beta Evo 80? Clutch is dragging a bit. Edited August 27, 201313 yr by frogger
August 27, 201313 yr ive been using putoline in ours and it has been fine just changed to atf and still the same but atf is a lot cheaper
August 27, 201313 yr I used Silkolene Light Gear Oil in both my lads beta 80's with no problems and good clutch action.
August 31, 201312 yr Author Thanks guys. I've used some Dextron III ATF, flushed out the old oil, fresh ATF again and it is superb now.
