October 29, 201313 yr My friend has just got a 99 techno and we are trying to remove the front wheel but the speedometer drive unit seems to be stuck to the axle. When we loosen the axle it trys to spread the forks apart. It also rotates with the axle. Any tips on how to remove it appreciated? Its number 45 on the photo below. Thanks!
October 30, 201313 yr Put a large sledge hammer against the one fork as a back up. Then push it through.(Tap it , don`t break it) Have had this happen even on a new bike.
October 31, 201313 yr Author Put a large sledge hammer against the one fork as a back up. Then push it through.(Tap it , don`t break it) Have had this happen even on a new bike. Thanks, i will give it a go tonight. Was afraid to force it in case there was some trick to taking them off.
