July 6, 200521 yr Can anyone give any guidance about setting my 2004 Rev 3's front and rear suspension? I'm about 13 stone and have set the front pre load as per the user manual guidance. I've set the front rebound adjustment at 15 clicks which I believe is mid range. I've set the rear adjustment mid range as well. Does anyone know how much pre load should be in the rear shock spring for my weight?
July 6, 200521 yr Race sag should be about 1/3 of your total travel with you on the bike. Probably about 2 1/2". At 13 stone, you could probably use heavier fork oil. ATF (about 7.5wt) or 10 wt.
July 6, 200521 yr Jon Stoodley's article on trials suspension tuning is excellent: http://www.gasgas.com/Pages/Technical/tria...nsion-tips.html Since I'm quite heavy (17st) I find that the best method is to wind everything up to the max then back off bit by bit until it feels right. Not very scientific but it works for me! Edit: Seconding what Charlie said: 7.5wt fork oil is the way to go. That 5wt stuff's like water! Edited July 6, 200521 yr by neonsurge
July 6, 200521 yr Just play about with it mate, get the front how you want it first and then start on the back
July 7, 200521 yr ok look i dont get stoned as much as you folks 13 stones ..good lord when do you find time to ride?????? ok so how much is a stone?
