May 13, 201412 yr Hi guys why is it when my 2007 rev 3 is upright i dont get any loss of fuel , but when i leave it on its side stand idling for 5 minutes or more it starts leaking, not loads but leaves a little puddle
May 15, 201412 yr I don't think it's float height Even if it was adjusted wrong it should not overflow And remember, it probably didn't do it new and now it does so something has changed and floats don't adjust themselves So its needle sealing, it's the only wear item in the area and it will change with time Replace the needle (it has opened and closed hundreds of thousands of times, it's tired) Use a Q tip and a little tooth paste and polish up the seat and of course set the float height correctly
May 15, 201412 yr Author Thanks 0007 i put a new needle float valve in about 3 weeks ago as the old one was really worn, but didnt use anything on it to seal it so thats maybe worth ago
