Beta Techno No Clutch Pressure
slim285
First bleed the master
Pump it a few times, hold the lever in and crack the banjo bolt, do this until you get no air
Remove the slave, press the piston all the way in and put a clamp on it
Then bleed for about 10 hours til you eventually get the hose free of air (total pain as the master flows very small volume)
If you have a vacuum bleeder you could suck the fluid from the master down to the slave which works a lot better
http://www.ebay.co.uk/sch/i.html?_trksid=p2050601.m570.l1311.R1.TR3.TRC1.A0.H1.Xvacuum+bleede&_nkw=vacuum+bleeder&_sacat=0&_from=R40
See above link. As you can now buy vacuum bleeder kits for well under £20 there is no reason not to have one.
Regular changing / vacuu bleeding of brake and clutch fluid prevents a lot of the problems you read about on TC
