Tlr Brake Shoes
Does anyone know the difference between the TLR200 and TLR250 brake shoes? A reputable dealer in the UK lists them as different parts. I ordered a set last year and cannot find a difference between the TLR250 shoes and the shoes for my TL125, both are a hub with a max diameter of 111mm.
Thanks
the 200 and 250 are different in many ways,the hubs, forks,tank,seat,side panels,exhaust.all very different.
The shoes in my TLR 200 are much smaller than the ones in my TL125 both have the interchangeable front and rear, Im guessing then that the 250 ones are larger than the 200.
TLTEL
TLTEL,
When you say 'much smaller' do you mean the diameter of the brake shoes when installed on the backing plate? How much smaller? Maybe the difference is the lining thickness. Do you know the hub ID on your 200? I have not been able to find a significant measurable difference of more than .010" (.254 mm) between the 250 shoes and my TL125 shoes. The hub ID is the same on both bikes.
Thanks
Off the top of my head the tlr200 shoes are around 10-15mm smaller diameter than the 250's and only 20mm wide, where as the 250's are 25mm wide.
yes. what he said. much smaller!
TLTEL
