Bultaco 198A
Hi
I have just picked up a 198a (I believe)
It has a square section swing arm and not the round reinforced one you would expect......
Could it be a cross over model from a-b
I will get some pics up tomorrow night and pop them up...
I was just after some thoughts ..
  • Replies 33
  • Views 9.7k
Most Popular Posts
  • ask greeves
    ask greeves
    Hi MJC, now you own a Bulto, this is when the learning curve, really starts. In no time you'll be a 'bulto anorak' ...just like the rest of us. I've found the biggest consideration, is 'deep pockets'
  • The swinging arms were lengthened on the M182/183[1976] by about 10mm. I am pretty confident all the swinging arms from that point on are all the same length. The Comerford bikes could have longer uni
  • some i did before
hello sounds like some 1 as put the 198B 199B later S/Arm on the 198A the box section S/Arm was only introduce in 1981 witch was the 198B model. i have a 198A frame and S/Arm spare with new bushes in them. but i do have 2 spare 199b S/arms i was thinking off doing the same on my 198A frame they are stronger. but i do like to keep them original. hope this helps.
on the other hand you could have a 198B model have you checked the engine and frame numbers? is the bike white are blue?
Hi I'm pretty sure it's a 198a...i am definitely going to check tomorrow...i think the frame was originally blue and has since been over painted white..its hard to tell it's a bit of a mess...it does have a rear frame loop...perhaps somebody wanted to copy a 198b. like I say I'll get some pics up tomorrow...thanks for the super quick reply
One photo I have not great but we all love pics
if it has the loop then the frame will be the 198A frame the Bs do not have the loop as you know. the only way to tell is looking at the engine number sounds to me it just may be the S/Arm off the 198B or the 199B
thoes are not original 198B S/Arms looks like some 1 has made them.
also seat it not the correct 1 looks like a fiber glass tank? see what you mean about the frame.
I thought it looked crude...
I will have to keep an eye out for a original A model swing arm. Like you I would rather have the original item.....also I need a left. hand side side panel would prefer genuine old aged item. Do you know where I should look first.
It's an ally tank
that looks like a alloy tank with the dent in it.
if you don't want to pay for new side panels just keep an eye on ebay they come up now and again. but you can buy brand new ones but they only come in pairs think there £47 i sold loads early this year i only normaly use new parts. but can cost alot.
I don't want to spend to much. And its not going to be a full restoration...i brought it to use and 2nd hand parts will be fine
Hi I'm not going to do a full restoration. I got the old thing to use. So 2nd hand parts will be fine where possible and will suit the bikes look
yes i understand then your better off just looking on ebay.
