November 12, 201412 yr Duh..... I feel like "The Dork of the Month" now..... I see the little "S" dealie below the "Font" box..... Thanks, Lineaway! You've bailed me out yet another time here! Back on topic, I guess I over thought my setup. I have a little funnel, stolen from my camping equipment (used to fill up my gas lantern & cook stove with it). I have a short piece of fuel line on the pointy end of the funnel, and then a section of bendable 5/16" brake line stuffed in the other end of the fuel line. The end of this brake line fits in the small hole where the oil goes in. The funnel has a little tang on it with a hole in that tang. I run a piece of wire through the funnel's tang, and then hook the other end of that wire to my exhaust guard. This all stays in place very well as I still overfill the goofy thing anyways...... Jimmie Edited November 15, 201411 yr by mr neutron
November 12, 201412 yr Just don't confuse your atf with your ketchup, Craig...... How did you get the "strike through" in your text above here??? Jimmie Dang, I thought my burger tasted rather tangy last time.
