2stroke4stroke Posted March 11, 2019 Share Posted March 11, 2019 11 hours ago, bradfordjonq said: Hi All, I realise this is an old thread but I’ve had 4rt starting problems recently and wanted to share the little trick I’d been given by the mechanic at Sandifords, Burnley. In short, I brought my 2015 4rt home on my trailer through some miserable wet and cold conditions, I spent a week pulling my hair out trying to get it started, checking electrical connections etc without any luck, in the end I phoned Sandifords and they told me to do the following - Open the Idle screw under the seat by another 2 full turns (factory setting for the tickover is around 3 full turns out). Fully open the throttle and slowly kick the starter to reset the ECU (the bike won’t start at this stage). Return the throttle to closed and kick start the bike as normal (no throttle). The bike should start with a high tickover. Turn the tickover screw back in until the tickover is ‘normal’. Hopefully that will save someone the hassle I had.. That seems a bit more complex than the standard two kicks at full throttle with the kill button depressed that I have to do frequently. Had you tried that method? Once you get the tickover set correctly you don't want to be fiddling with it unless absolutely necessary. Quote Link to comment Share on other sites More sharing options...
bradfordjonq Posted March 11, 2019 Share Posted March 11, 2019 1 hour ago, 2stroke4stroke said: That seems a bit more complex than the standard two kicks at full throttle with the kill button depressed that I have to do frequently. Had you tried that method? Once you get the tickover set correctly you don't want to be fiddling with it unless absolutely necessary. Agreed, but I tried the two kicks method you mention above with no joy whatsoever, so what I’ve passed on is a final resort if the usual methods don’t work, it worked for me.. 1 Quote Link to comment Share on other sites More sharing options...
