January 11, 201511 yr hi just wanted to know if you can fit an ajp calliper to a formula master cylinder thanks higgy
January 12, 201511 yr There are 2 different types of Banjo fittings M12 (older style) and M10 Newer style. As long as the ajp caliper has the same size it will work. Otherwise you will have to get a hose made up with a different bottom fitting. Check 1st to make sure you get the right caliper. I'm not sure what size the formulas use, Someone will surely post the info for you.
February 1, 201511 yr Author thanks I have got a new venhill hose so I'm hoping I can get a new ajp caliper to fit. thanks again
