September 4, 200521 yr On my uncles 1998 beta techno there is a small black box under the header tank bolted to the frame with one yellow wire coming out of it. What does it do? just wondered if it varies the power supply to the fan or lights or somthing? The fans power lead (yellow one) is conected directly to the yellow wire coming from the engine is this ok? or does the black box thing need to be joined in somewhere, to stop the fan being blown up or something? Any one got a wiring diagram i could have? James
September 4, 200521 yr Author so just join the wire in with the other 2? so theres a bunch of all 3 wires joined together? James
September 4, 200521 yr james.I will try and attacth a diagram.Iam not sure how it will appear,the yellow wires are a bit faint
September 4, 200521 yr Author Thanks Mort so you basically join all 3 yellow wires together providing you dont want the lights on. sorted Cheers James
