A Proper Look At The Trs Chassis
  • Replies 76
  • Views 28k
Most Popular Posts
  • 2stroke4stroke
    2stroke4stroke
    Not totally, I have just had to replace the bottom bearing when it developed a very small amount of play after only 11 years of use. Disgraceful; how I wish I had bought one of these wonderful Gas Ga
  • biffsgasgas
    biffsgasgas
    What I can conclude out of this post is that no matter what suspension it will have it will not pass the test! TRS has a mythical frame that will somehow support the weight of Raga. It will be filled
  • neils on wheels
    neils on wheels
    The 'levers' are not there to smooth out the action, arguably they would do the reverse by adding friction. Their purpose is to change the leverage ratio applied to the shock to control the rate at wh
When the weight thing came in we looked at the scales in france and Tonis bike is the same as the 2 strokes from memory, but on the fim limit for sure.
Whether its lighter than minimum and they bung a lead weight in the airbox before scruitineering is anyones guess.
Like this :)
Adding weight to the bike isn't cheating. Taking it off again in a competition might be.
Which is another FIM pet hate of mine, why not weigh bikes at random?
Too easy to circumvent current rule
Edited by nigel dabster
Can't see what it matters how heavy the bike is?
Implement more and more rules to drive people and manufacturers away from the sport which isn't exactly thriving???
why cheat
What I can conclude out of this post is that no matter what suspension it will have it will not pass the test! TRS has a mythical frame that will somehow support the weight of Raga. It will be filled with led and the trials community will scrutineer it to death.
On that note to maintain status quo let me start a new focus of scrutineering. I bet the exhaust tip will be absolutely horrible!  Probably too heavy or not made out of some material that you googled moments ago. Lets storm the factory in protest!
--Biff
PS. The factory confusion as to why an angry mob is at their door is just a sign of aggression so don"t fall for it!
Truly remarkable, I actually agree with Dabster on this one
I understand that testing of the TRS in Spain has been very impressive. It has more power and zip than a JGAS and the balance is spot on. We know Jordi Tarres can design a good bike but he may have just gone one better with his new baby  :)
