penno350 Posted May 10, 2015 Share Posted May 10, 2015 Evening Guys, are Bulto forks inherently 'wobbly' only really noticed since I have been trying harder sections and particularly rocks but at times it seems like the front wheel is pointing in a different direction to the bars, everything in terms of clamps and spindle is tight and as it should be? Quote Link to comment Share on other sites More sharing options...
lbhbul Posted May 10, 2015 Share Posted May 10, 2015 Generally speaking the older style forks are not as ridged as the modern style, mainly due to diameter 35mm versus 38 to 40 mm but IMHO it is where the fork bracing/ fender mount placement occurs. In my experience if you should crab a bit you may need to find a couple of trees the proper width apart to realign things, this activity is to be avoided as much as possible but will occur anyway. Will have photos shortly. Larry 1 Quote Link to comment Share on other sites More sharing options...
woody Posted May 10, 2015 Share Posted May 10, 2015 Depends on the fork brace, some are more rigid than others but no idea which is the best. My M92 twists all over the place, especially on rock sections and I have to regularly kick the wheel back into line. Another couple of bikes flex a bit and another bike is quite rigid. They all have aftermarket braces, as far as I can tell, all the same... Quote Link to comment Share on other sites More sharing options...
bullylover Posted May 11, 2015 Share Posted May 11, 2015 The Sammy Miller mudguard brackets seem to be a bit stiffer than the standard brackets. This helps the forks a lot. If you have a look at a few photos of the Puma bikes you will see they have aluminium mudguard brackets on them which look to be very stiff and would stop the forks from moving at all. Graham. 1 Quote Link to comment Share on other sites More sharing options...
penno350 Posted May 11, 2015 Author Share Posted May 11, 2015 Thanks guys, was thinking improved fork bracing would help. Quote Link to comment Share on other sites More sharing options...
lbhbul Posted May 11, 2015 Share Posted May 11, 2015 (edited) Maybe these photos which I failed to post last evening will be of some help, my 199 seems to stay pretty straight but then I don't ride rocks much or anything else like we all once did. Larry very un-twisty, too harsh for my thinking, I prefer the nice soft Bultaco fork action. Edited May 11, 2015 by lbhbul Quote Link to comment Share on other sites More sharing options...
bultaco 199 Posted May 12, 2015 Share Posted May 12, 2015 My standard bike (199b) with no mods if you do big jumps and hit the end stops it has twisted the forks a few times I simply loosen off the front end and put it between my legs and pull it back. I did try it with out the loosening off and it seems to still come back ok. It never moves too far and is still very rideable. Martin. 1 Quote Link to comment Share on other sites More sharing options...
