September 15, 200520 yr has anybody had trouble with rev 80 beta electrics mine has just started to play up when i start it it runs for a minute then stops reving and missing as though it has a carb full of water when i change the plug it runs ok for a wile now it has gone of song completly and is stalling and not reving out does this sound like elecs
September 15, 200520 yr Whats the plug look like when you pull it? the REV series has a reputation for "oiling up".
September 15, 200520 yr The last plug in my sons Rev 80 lasted nine months, get the carb set up right, change the plug cap to the blue ones, check the kill button is'nt earthing out, ( run the bike in the dark and look for sparks jumping around). If all this fails speak to Gary at JLI,( but don,t blame him)
September 16, 200520 yr Author the plug is prob a bit blacker than should be but is wet as though it has flooded will weaken of and try a new plug cap and check kill switch
September 16, 200520 yr Also try "running out" the fuel after a trial and make sure the Air-filter is clean and oiled.
