cosmo Posted July 17, 2015 Share Posted July 17, 2015 Hello all.Recently returned to bultaco ownership after a 25 year gap.Im looking for advice please.Purchased a very rattly m80 with alloy tank frame number B8001649 to restore and ride.All going well and pretty enjoyable so far:frame welds fixed,resprayed,swing arm bearings, shocks and wheels done,however hit a problem with removing fork bottom section.I have removed full fork assembly as a pair during other work and replaced steering head bearings,now trying to remove bottom section of fork(slider),i have followed clymer and haynes manual instructions and now have chrome section of fork legs individually in a padded vice,removed bottom allen release screw and rubber fork seal dust cover from bottom section,however fork sections wont pull off and separate as suggested but seem to hit a definite stop at full extension,also no sign of any circlip under rubber dust cover on top of fork seal?l.Do i need to reassemble fully on bike and try again?or am i doing something i shouldnt with fork legs individually in vice?i dont want to force too much in case of causing any damageAny help much appreciated.Thanks in advance. Quote Link to comment Share on other sites More sharing options...
lbhbul Posted July 17, 2015 Share Posted July 17, 2015 Cosmo, Unless there has been a long 6m screw turned in against the damper they should only be stuck to the bottom of the slider with accumulated gunk or corrosion. Damper assembly the damper is secured in leg by a circlip, the slider comes off after the bottom 8m allen head is removed. Be sure to replace the O-Ring seal. Larry 1 Quote Link to comment Share on other sites More sharing options...
cosmo Posted July 17, 2015 Author Share Posted July 17, 2015 larry,many thanks for your informative reply,i will try again over this weekend with a bit more grunt. Quote Link to comment Share on other sites More sharing options...
lbhbul Posted July 17, 2015 Share Posted July 17, 2015 Cosmo, a help would be a longer M8 bolt screwed well into the damper, then tapped with a small hammer along with some penetrating oil, should come along nicely, springs out of course. Let us know how you get on. Larry 2 Quote Link to comment Share on other sites More sharing options...
cosmo Posted July 20, 2015 Author Share Posted July 20, 2015 Larry,forks now separated pending reassembly,I will post some photos of the rebuild soon.Many thanks.Stuart . 1 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted July 21, 2015 Share Posted July 21, 2015 as for your other question about the lack of a circlip above the seals, that is quite normal for those forks. The friction fit of the seals in the fork bottom section is all that is needed 2 Quote Link to comment Share on other sites More sharing options...
lbhbul Posted July 21, 2015 Share Posted July 21, 2015 (edited) Stuart, my best luck with seals; removal can be facilitated with a bit of heat and careful levering and soft alloy to lever against so as not to harm the slider,( I don't own a proper seal puller ). 1 seal per leg 35x47x10, I like to cut the female end of the seal spring by about 1/4 inch to ensure better sealing, (not my idea but it sure works). Good Luck Larry Edited July 21, 2015 by lbhbul 1 Quote Link to comment Share on other sites More sharing options...
cosmo Posted July 22, 2015 Author Share Posted July 22, 2015 Gents,i have new fork seals and springs waiting to be fitted hopefully this weekend coming.I will post progress.Thanks again.Stuart. Quote Link to comment Share on other sites More sharing options...
