Tx250 Con Rod Kit
Is it possible to obtain a con rod kit for a TX250?
Thanks
This should be the same as the FM350 con rod kit I bought a couple of months ago.
I got mine from Steve Goode, kit came with rod, big end pin and both bearings. I also bought the the little end gudgeon pin as mine had seen better days.
fantic conrods.pdf
  • 3 months later...
Just got hold of a TX250 bottom end with good big end - I hope ! Will let you know how it runs shortly - could be a while though !
