October 6, 200521 yr Hi. Rev3 250 2000 I was checking the carb settings on my bike and the air screw is set at 3 turns out, can anyone confirm this is standard? Thanks,
October 6, 200521 yr my 2000 with 145main and 27.5 pilot jet and n7yc plug seems to like it between 2.5 and 3 turns out. I do have the idle set slightly high if someone knows more chime in
October 7, 200521 yr Two turns with "V" groove on front of slide. Reduced shroud on needle jet? Smoothed bore!
