October 10, 200521 yr Hi i have just got my son a fantic 300 im led to believe its an 1985 model it has front and rear disc brakes i need help finding the correct fork seal size as one of the fork is leaking the 2 sizes are Fork Seals 32mm x 42mm x 8mm or Fork Seals 35mm x 47mm x 7.5mm i dont want to take the forks in bits as im not that confident and have someone who could maybe do it for me also i wouldnt mind replacing the silencer on the back as it has a hole where the tyre has rubbed it (getting it rewelded) i was thinking of maybe a newer style (less noise) any help would be most welcome thanks graham
October 10, 200521 yr Graham, The best guy to ask is Bill Pye, he knows Fantic through and through - best place to get parts for Fantic bikes in the UK. If you live near the North East of England, the address is Frankfield Garage Great Ayton Middlesbrough North Yorks TS9 6BZ Give him a call on 01642 722378 - he will help you out. Stuart
October 10, 200521 yr Author Just had an email from someone who gave me an address for a site so i can tell which bike i have.and from the pictures the fantic 300 has twin shocks 1983 but mine has a monoshock ? unless its had a tank from a fantic 300 ? as it says 300 on the tank im unsure will have to check tommorow in the light to see if there are any more things i can identify it with strange though
October 10, 200521 yr Fantic 301 maybe? I had a Fantic 301 around that sort of time. Don't remember whether they did one with a rear disc brake though? Edited October 10, 200521 yr by bikespace
October 11, 200521 yr Graham This is the earliest fantic I can think of and find with both F&R disc brakes, it is a 1987 303 model. If it is not this bike, it may be possible that you have got an older model that had its brakes converted to disc by someone?? Stuart Edited October 11, 200521 yr by stuthescot
October 12, 200521 yr Hello, If you want to know which model you have then you have to take a look at my website: www.fantic.nl. And yes the fist model with front and rear disc brake is the Fantic 303 from 1987. You can put two seals in one leg 47x35x7 - rst and 47x35x10 - rs (information also available on mine site look at "Restauratie 303 - Onderdelen".
