86tlr200 Posted February 28, 2016 Share Posted February 28, 2016 Hello, I'm looking for an aftermarket (stronger) kick starter pivot for a TLR200. the one i currently have on my bike is aftermarket, it is starting to get worn out, it won't stay in the folded position. when i bought the bike it had a small box of parts, mostly junk, but in it were two stock pivots and both were cracked. does anybody know of replacement parts that would be stronger. Thank you Brian Shelton WA Quote Link to comment Share on other sites More sharing options...
4stroke Posted February 28, 2016 Share Posted February 28, 2016 Do you have the decompressor fitted and working? Saves the kick starter and gears. Quote Link to comment Share on other sites More sharing options...
86tlr200 Posted February 28, 2016 Author Share Posted February 28, 2016 Hello, I do not have a decompressor installed. Brian Quote Link to comment Share on other sites More sharing options...
4stroke Posted February 29, 2016 Share Posted February 29, 2016 The standard bikes had an auto system fitted. When you put pressure on the kick start the exhaust valve would be opened. I use a finger operated lever to do the same. Takes a lot of strain from the starter gears, shaft and kicker. Quote Link to comment Share on other sites More sharing options...
86tlr200 Posted March 1, 2016 Author Share Posted March 1, 2016 sorry, i meant I DO have the decompressor installed Quote Link to comment Share on other sites More sharing options...
lineaway Posted March 1, 2016 Share Posted March 1, 2016 I believe it has an adjustable cable. You might see if it is actually working. I have seen the starters get wobbly, but never broke. Quote Link to comment Share on other sites More sharing options...
86tlr200 Posted March 9, 2016 Author Share Posted March 9, 2016 the cable is working properly, attached is a picture of the broken part. i would like to get a new (better) part, if im going to replace this one, rather go with a stock part. Quote Link to comment Share on other sites More sharing options...
lineaway Posted March 9, 2016 Share Posted March 9, 2016 Is there a kick start stop that could be bent up causing this. I seem to remember an odd piece fitted around the frame foot peg location on the USA model. Quote Link to comment Share on other sites More sharing options...
