mickmc Posted March 6, 2016 Share Posted March 6, 2016 hi the fan stopped working today on our beta evo 125, i don't have a voltage tester so could i test it with a car battery, to see if the fan is working and that it isn't the thermostat, would that be the correct voltage ?? thanks Quote Link to comment Share on other sites More sharing options...
sirdabalot Posted March 6, 2016 Share Posted March 6, 2016 Put the two thermostat wires together then start it up. If the fan spins it'll be the thermostat. If it doesn't it may be the fan, but try a test bulb to the thermostat supply wire first (better than a meter as it'll show if the supply has enough guts to run the fan). 1 Quote Link to comment Share on other sites More sharing options...
