stelio10gr Posted July 25, 2016 Share Posted July 25, 2016 I have recently bought a txt 250 '03 and I was just wondering how I can set the front and rear shocks up to a more bouncy mode, weigh only 65 kg and it makes it very difficult to bounce the rear. Quote Link to comment Share on other sites More sharing options...
stelio10gr Posted July 25, 2016 Author Share Posted July 25, 2016 On the top of your forks you will find some plastic dials. Turn them anti clockwise until you cannot turn them any more.[DO NOT USE FORCE] On the rear shock you will find a silver protrusion that a small spanner can fit on [it comes out of the side of the shock body] turn this anti clockwise until it will go no further[DO NOT USE FORCE or you will snap it off] You may have to remove the airbox to gain access to it. This will give you the softest[bouncy] settings. Thanks ...I ll try that. Quote Link to comment Share on other sites More sharing options...
beta_blocker Posted July 25, 2016 Share Posted July 25, 2016 Read this article. It is full of important information every trials rider should understand on setting up your suspension. If you don't start out getting your spring rate/suspension sag correct for your weight and proper fork oil, you will have trouble making adjustments to your bike to make it handle correctly. https://www.joomag.com/magazine/trials-enduro-news-december-2014-volume-49-issue-12/0716551001416757092?page=61 1 Quote Link to comment Share on other sites More sharing options...
