Sprocket Sizes
I've gone to change my sprockets today and last time I
Was in the ossa dealer I bought a set which was front
10 and rear 42 but I've noticed the front I currently have
On is an 11, can anyone tell me what the standard set up
Should be on a 2013 300 factory rep
I ran 10 front 41 rear ran spot on the standard is 10 front 42 rear ,mine was the 14 factory R
Excuse my ignorance but what difference will
It make to the bike if I put the 10 sprocket on ?
As I do like it as it rides
Edited by jsp
11 tooth front may cause the bike to push in the tight sections a 10 tooth is much better ,its the same as 4rt owners most change the gearing to a 9 tooth front sprocket ,the ossa does have a lot of power and this will calm it down a bit .
I'll give the 10 a go then, I must admit this weekend it did seem to be a bit quick in sections
Will first still be the gear of choice ? That's all I seem to use on it now for most sections
Edited by jsp
Yes I STILL used first almost all the time and second on bigger hills
cheers I'll get it fitted, the previous owner must have changed it
for some reason
Mine came with a 10' I have thought about trying a 9 but haven't got around to it yet.
