September 6, 201610 yr Trying to remove the water pump impeller in order to remove the RHS engine case to inspect the clutch. Does the impeller pull off with the Case? I do not want to simply pull the impellor out if it's fixed behind the case etc and potentially break something . I can only assume that the impeller & shaft assemble can be pulled out with some pliers or the impeller is attached to the shafts with a LH thread? Either way do I pull the impellor off with the Case or am I missing something? The impeller appears to be the only thing holding case on now that I have removed the bolts, kick-start & water pump case. Cheers Tony
September 6, 201610 yr Author Sorry, new phone with predictive text. Post title = scorpa sy250 water pump impeller removal
September 7, 201610 yr [look on Nigel Birketts site sure that there are pdf manuals you can download from there Sorry, new phone with predictive text. Post title = scorpa sy250 water pump impeller removal
