Jitsie kill switch on a rev3
Just back from a trial today I have a jitsie magnetic kill switch fitted at section 6 I stopped bike using the kill switch started it again rode the section and at section 7 tried to use the kill switch to stop the bike again and the engine just kept running I have tried the magnet on and and off a few times Aswell as gentle tapping to see if the inside is stuck up but no joy any advice on what I could try would be great
Thanks in advance hopefully get this sorted soon
Thanks bad punctuation
It's been fitted for a year do do you think it could be a broken wire somewhere i am really not good at electrics i thought maybe something was stuck but tapped it a few times and nothing
OK thanks so if a wire is crushed or broken would the bike continously run when I take the kill switch off
Not crushed, only if it is broken, just squashing the wire does not necessarily break the internal conductor.
My kill switch is jitsie no solders underneath just like waterproof Jelly stuff I have rewired the wire I thought was broken and I have a circuit on both the wires but the bike still won't stop when I disconnect the kill switch I have checked continuity from as near to the switch as I can and it seems OK
The earth behind the light looks good I have 4 wires and just have the 2 that come from the kill switch wired into the matching wire down on the fight hand side of the fuel tank
Take the earth direct from the kill switch or from down the bottom how would I attach this new wire sorry for questions I am not very good at thus stuff and nowhere near me to put my bike to get work done
I have tried putting it on and off quickly alot of times but not spinning it I can hear the kill switch clicking when I put the magnet on and off not sure if this means it's working or not
