walshy_7 Posted May 28, 2017 Share Posted May 28, 2017 Recently purchased a gasgas 300 and I'm made up with the bike but after a few outings I thought it best to do some maintenance It's had a very heavy clutch and this site has been brilliant for finding out how to resolve this issue Also the fork seals have give up so after a great day at hawks nest I decided to pull it apart to sort the heavy clutch when removing the sump plug it let out a lot of loverly emulsified creamy oil so a little research and I'm going with water pump seals whilst removing the engine casing I seen that previous owner has smeared gasket glue all over the face of the water pump housing when I started to remove the couch plates I found loads of gasket glue jammed in every where also in the sump very rough job had been done on the bike so looks like I've got to do abit more than just changing oil I'll try and upload some pictures now All comments and thought welcome Regards chris Quote Link to comment Share on other sites More sharing options...
robd0gg Posted June 12, 2017 Share Posted June 12, 2017 wow.. not sure I have anything to help you with, but that's pretty disturbing how's it coming along? Quote Link to comment Share on other sites More sharing options...
walshy_7 Posted June 13, 2017 Author Share Posted June 13, 2017 Thanks for the comments guys and well bikes brilliant again now I've took the cheap option of fixing it and I've done about 10 hours riding now fault free see how long it lasts. I've sanded down the clutch plates and put fresh oil in also fresh oil on the forks and replaced the seals and with the water pump the shaft was worn so looked into replacing the shaft and seal but I settled with using my original seal and shaft and fitted smaller springs on the seal and upto now all is great 1 Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted June 14, 2017 Share Posted June 14, 2017 Keep your eye on the transmission fluid. It will get milky when the coolant leaks past that worn shaft. And it will. Replacement shaft and seal are available as a set at a reasonable cost. Remember that the oil lubricatesall the gears, bearings and clutch parts. Water and coolant are poor lubricants. Quote Link to comment Share on other sites More sharing options...
walshy_7 Posted June 14, 2017 Author Share Posted June 14, 2017 Yes matey I will be keeping a close eye on it and to be honest mate I'm not expecting it to last long really it was just a temporary quick fix as I had oil there and wanted to be out riding that day Quote Link to comment Share on other sites More sharing options...
paulmac Posted June 16, 2017 Share Posted June 16, 2017 Don't forget that on the Pro engine the gearbox oil also lubricates the crank bearing - water in there isn't a great idea. Quote Link to comment Share on other sites More sharing options...
walshy_7 Posted June 16, 2017 Author Share Posted June 16, 2017 Yes mate cheers I have now ordered a water pump and new gaskets loving the bike now I'm going to look into entering some events soon hopefully it's just hard finding out about these evens 2 Quote Link to comment Share on other sites More sharing options...
collyolly Posted June 16, 2017 Share Posted June 16, 2017 Go to the ACU website and on the front page in the middle you will get access to all of the ACU clubs in the U.K. Make contact with a couple of clubs near you and find out what they and your centre in general offers as far as organised trials / practice events. Not sure how much goes on in your part of the country but down here in the south east you could join 2 or 3 clubs and very easily be riding most weekends within an hours drive. Quote Link to comment Share on other sites More sharing options...
