July 26, 20179 yr I am rebuilding a JCM 240 Europa from the late 80s. when I was replacing the fork seals ( I believe these should be Marzocchi ) I found the internals of the 2 forks are completely different. is this normal & does anyone have a parts diagram or any maintenance info on these forks?
July 26, 20179 yr Hi Yes that is normal you can find a diagram on the gas gas website its in the parts book for the 1991 327 aire model any problems pm me and ill dig it out for you Cheers Paul
July 26, 20179 yr You will probably realise it from the parts diagram but please note the seals are different in each leg. From memory one side has one wide seal the other two thinner ones, only one side has a retaining circlip also. Edited July 26, 20179 yr by topline620
