October 16, 20178 yr Hi guys that’s me joined hope you can help , any info or talk through pics ect on how to repack my Sherco st 300 factory 2017 exhaust its a OXIA hope you can help .
October 17, 20178 yr Remove philips bolts that hold the plastic part (in mine 2015 I need to remove the silencer not shure if you need too. Probably not) Using gloves, remove old fiberglass and clean (burn or wire brush) perfurated pipe. Put new fiberglass mat. Mount everything in place again. Use threadlock in silencer to frame bolts
