jontribe Posted March 30, 2018 Share Posted March 30, 2018 Hi Chaps I'd like to do some dual sport events on my 199a, I did the Michaux PA. meeting last year, but could not complete it because I need an 80 mile range which my stock setup tank does not have. I'd really like to do it this year, it being the last one. Can anyone help, was there a larger Bultaco tank ever made, not sure there was. Has anyone ever come across this issue and solved it?? Anyone know a different larger tank that would fit? Any ideas/advice would be gratefully received!! TIA Quote Link to comment Share on other sites More sharing options...
model80 Posted March 30, 2018 Share Posted March 30, 2018 (edited) A late model Alpina model 212 or 213, tank and saddle might do the trick. I saw at tank at the Stafford Show in the UK last year and thought that would be useful for longer distances etc. Only reason I didn't buy it the inset nuts for the later type fuel tap were pulled clean out of the tank, from over tightening. Edited March 30, 2018 by model80 Quote Link to comment Share on other sites More sharing options...
peterb Posted March 31, 2018 Share Posted March 31, 2018 You could fit a 1L Hebo or similar type fuel tank to the forks in between the yokes (triple clamps) if this is going to be enough for the event. Bye, Peter B. Quote Link to comment Share on other sites More sharing options...
sherpa325 Posted March 31, 2018 Share Posted March 31, 2018 If your bike has the original plastic tank it is listed as 1.1 gallons. The earlier 159 - 191 fiberglass tanks are listed as 1.4 gallons and will fit straight on. You could also gear the bike up, standard gearing is 11/39, so you can put either a 12T or 13T front sprocket on depending on the terrain of course. Cheers Greg Quote Link to comment Share on other sites More sharing options...
model80 Posted March 31, 2018 Share Posted March 31, 2018 41 minutes ago, sherpa325 said: If your bike has the original plastic tank it is listed as 1.1 gallons. The earlier 159 - 191 fiberglass tanks are listed as 1.4 gallons and will fit straight on. You could also gear the bike up, standard gearing is 11/39, so you can put either a 12T or 13T front sprocket on depending on the terrain of course. Cheers Greg The 159 or 191 tanks were fibreglass (outside the UK) as standard, so that presents it own problem with modern petrol. Quote Link to comment Share on other sites More sharing options...
sherpa325 Posted March 31, 2018 Share Posted March 31, 2018 Pretty sure the fiberglass tanks are ok as long as there is no ethanol in the fuel. Quote Link to comment Share on other sites More sharing options...
scifi Posted March 31, 2018 Share Posted March 31, 2018 The old trick for long distance events was to hide a couple of spare tins of fuel behind trees along the route. That was if you had no support crew. If you are allowed a helper, then arrange to have re-fueling stops with them every 30 miles. . Quote Link to comment Share on other sites More sharing options...
jontribe Posted March 31, 2018 Author Share Posted March 31, 2018 Thanks for all the input guys... Looks like a later Alpina tank might be the best option, does anyone know what capacity they were. Thinking if they were over 2 gal that would do me... Quote Link to comment Share on other sites More sharing options...
twinnshock Posted March 31, 2018 Share Posted March 31, 2018 (edited) I see that you are from the states so your gallons are smaller than ours over here in the UK. So best to quote metric. My Bultaco book lists the late Alpina tank at 8.5lt. I bought an Alloy Alpina tank for my M188 (listed as Sherpa) of ebay from India last year and am very happy with it. We have to much ethenol in our UK fuel now which destroys the fibreglass tanks. US Gallon 3.78lt UK Imperial Gallon 4.52lt The Alpina tank is different at the rear where the seat aligns so you might have some issues with the seat. Stuart Edited March 31, 2018 by twinnshock spellling Quote Link to comment Share on other sites More sharing options...
