September 16, 20188 yr 59 minutes ago, KompeMax said: How much air should i use in a trial tire? Front ? Back ? For forest use Front 5.5 psi muddy to 6 psi dry Rear 3.5 psi muddy to 4 psi dry All approximately. Edited September 16, 20188 yr by oni nou
September 16, 20188 yr Author 9 minutes ago, oni nou said: Front 5.5 psi muddy to 6 psi dry Rear 3.5 psi muddy to 4 psi dry All approximately. Thanks!
September 16, 20188 yr I agree with oni nou on forest riding pressure and will note that If your trail riding in sharp rocks at speed I would add a psi to each to prevent punctures.
September 17, 20188 yr Author 15 hours ago, jonnyc21 said: I agree with oni nou on forest riding pressure and will note that If your trail riding in sharp rocks at speed I would add a psi to each to prevent punctures. Thanks! for the tip c:
