October 9, 20188 yr You've done well there! hopefully you won't need to do it again. A club member was having trouble and pumped 500ml through it and still no brake. Turned out that he thought he should shake the bottle well before use! ?
October 23, 20188 yr Author richt. If i have to do it again at least now i know how to do it the easy way. After i found out how to do it the easy way it was a max 20 minutes job I guess it would have been more easy if the rear brake cylinder/master pump also was the reservoir like it is on the newer Gas Gas trials
