April 3, 20197 yr Hi Folks,I've just got a jitsie replacement throttle cable for my Beta 300 4T 2011.The cable I got was stated to be for 2009 to present,all nipples and adjusters are right but the inner cable has about 15mm more length coming out of the outer than the old one and theres not enough adjustment to take the slack up ,anyone know if specific carbs require a specific cable ,my carbs a mikuni. cheers.
April 3, 20197 yr Do you have the Beta twist grip or Domino? I had problems when I fitted a slow action to mine.
April 3, 20197 yr There are two nipple positions on the quadrant on the carb. I had to change to the “other” when I fitted an Amal slow throttle.
April 4, 20197 yr Author 9 hours ago, 4stroke said: Do you have the Beta twist grip or Domino? I had problems when I fitted a slow action to mine. Its a Domino.
April 4, 20197 yr Author 8 hours ago, trapezeartist said: There are two nipple positions on the quadrant on the carb. I had to change to the “other” when I fitted an Amal slow throttle. Yea saw that .its on the right one,if I had it on the other it would be even worse.
April 4, 20197 yr Author Got it sorted thanks ,I put a plastic insert on the outer inbetween it and the twistgrip ,got me another 5mm, its still goes into the grip housing enough,thanks for the replys.
April 5, 20197 yr Author On 4/3/2019 at 10:12 PM, 4stroke said: Do you have the Beta twist grip or Domino? I had problems when I fitted a slow action to mine. In the 4t manual it talks of adjusting the throttle cable at the twistgrip and at the carb ,I only have adjustment at the carb and it actually doesnt show one on the parts illustrations so was wondering if you have a cable adjuster at the twistgrip.Cheers Edited April 5, 20197 yr by lunesdale
