neilfrancis Posted April 15, 2019 Share Posted April 15, 2019 Hi. Is the disc valve timing on a climber the same as a swm. Thanks Quote Link to comment Share on other sites More sharing options...
b40rt Posted April 15, 2019 Share Posted April 15, 2019 2 hours ago, neilfrancis said: Hi. Is the disc valve timing on a climber the same as a swm. Thanks I'd be very surprised if it wasn't, but stand to be corrected. Quote Link to comment Share on other sites More sharing options...
neilfrancis Posted April 16, 2019 Author Share Posted April 16, 2019 Hi. I think I've worked it out now. At tdc the disc can either be about 5 mm covering the port or about 10 mm before. There were some faint marks on the case where it had previously been marked. I'm sticking it back together with the port uncovered.Thanks. Quote Link to comment Share on other sites More sharing options...
2muchstuff Posted September 21, 2020 Share Posted September 21, 2020 Hi, I'm having trouble with finding out how to set the rotary valve timing on my Aprilia 280 climber, thanks Quote Link to comment Share on other sites More sharing options...
