September 27, 20197 yr Hi, any ideas would be a great help ....my 12v font lamp has stopped working (bulb is fine) i have measured the voltage across the switch and with a bit of throttle it maxes out at 5 volts ...is there a regulator tucked away somewhere i need to check cheers Neil
September 28, 20197 yr I’m not sure about the 2015 but the earlier bikes powered the incandescent bulbs from the ac windings pre-regulator. The fan and, I believe, the microcontroller in the CDI ran off the 12V from the regulator. The new bikes with the LED bulbs run the lighting off the 12V from the regulator. Worth looking at the documentation on the Beta website.
September 28, 20197 yr Author Thanks Dan, Yes its 12-vac direct from the stater on tracing back i found poor connections (mucky corroded) at the ecu location, there are connections there regards Neil
