superlative82 Posted November 3, 2019 Share Posted November 3, 2019 Hey All, just after some general advice on getting my son his first trial bike. He is just starting out and has had a handful of lessons and is now moving onto trials lessons. For a 9 year old what is the generally the first trial bike they move onto? Thanks in advance Quote Link to comment Share on other sites More sharing options...
breagh Posted November 3, 2019 Share Posted November 3, 2019 Hi there choice is fairly limited,either an Oset 20r or a Beta 80 small wheel. I've both, Oset needs a lithium battery to be any use which makes it expensive and it has limited off road ability. I find it fine for playing, Beta's more up for it,rides like a proper small trials bike which it is, weak point is the hubs, holds it value well and quite sought after. 1 Quote Link to comment Share on other sites More sharing options...
gasserguy Posted November 4, 2019 Share Posted November 4, 2019 For 2019: CLARIFICATION OF YOUTH CLASSES (See ACU Handbook TSR1 (page 197) for full details) Note BIG change to B class for 2019: riders born between 1.01.2007 and 31.12.2007 have the option of either: • Moving to the B class in the year in which they reach 12 yrs on a machine up to 125cc (and being eligible for B Class points ) OR • Remaining in the C Class for another year on a machine of up to 80cc and retaining eligibility for C Class points. Youth Age Groups: A Class born between 01.01.02 and 31.12.03 B Class born between 01.01.04 and 31.12.07 C Class born between 01.01.08 and 31.12.09 D Class born between 01.01.10 and 31.12.13 E Class: minimum age 4 years at the date of competition. Minimum age for combustion engine machine is 6 years. ENGINE CAPACITY CLASSES: The maximum engine capacity and wheel size permitted for machines used in the age groups set out in this Regulation are as follows: A Class 125cc Mono or 250cc Twinshock, and Electric up to 10 bhp measured at the rear wheel B Class 125cc Mono or 250cc Twinshock, and Electric up to 10 bhp measured at the rear wheel C Class Standard Wheel 80cc, and Electric up to 7 bhp measured at the rear wheel D Class Medium wheel 80cc, and Electric up to 7 bhp measured at the rear wheel E Class Small wheel Electric powered machines up to 2 bhp measured at the rear wheel C & D class may be split by wheel size: C class: standard and medium D class: medium and small Wheel sizes Standard Wheel – 21" Front – 18" Rear Medium Wheel – 19" Front – 17" Rear Small Wheel – 16" Front – 14" Rear The above is based on the wheels of combustion engined machines using motorcycle tyres. If other wheels are used as on current Electric powered machines then the outside diameter (total circumference) of the tyre must not exceed that of the corresponding tyre size. Engine Sizes Rebores are permitted subject to the resulting engine capacity not exceeding a tolerance of +3cc Quote Link to comment Share on other sites More sharing options...
