May 20, 20206 yr Hi Folks, Chasing some advice / knowledge about Gas Gas shocks fitting Sherco's. My son has been offered a second hand 5 way adjustable Reiger shock at a good price. But shock has come off a 2015 Gas Gas 300, does anybody know if it will fit a 2018 Sherco 300 Factory ?? I've been onto some Reiger websites but cant find any info. Thanks in advance, Gary
May 22, 20206 yr Is it the same length between the mounting bolt holes?Also the same width across the mountings,less important if you can get mounting bushes made.Remove your present shock and get measuring,ask the Reiger owner to do the same
