January 29, 200620 yr hi. i was out today and was riding in the stream when the front end of my bike droped of a ledge. the water more or less covered my handlebars. i managed to eventualy start it but could it have caused any damage. i gave it a good pelt over the moors and all seemed ok. when i got home i realised that water had got into the gear box oil so i drained it and changed the oil but the oil has gone cloudy again. what is the best way to get rid of the water? is it to keep changin the oil? thanks. its a gas gas 2003 200 pro
January 29, 200620 yr Check and clean out the Airbox, Air filter and carb. It does sound as though you may need to check the water pump as well. If the seals on the shaft are worn or damaged they could be letting water into the gearbox.
January 29, 200620 yr Drain the gearbox oil,then re-fill with petrol (2 stroke mix)the same ammount as you would put in if it was oil,start bike and run for a couple of minutes,drain and put in the cottect ammount of oil.I have done this a couple of times on my bikes,the advise was given by a proffesional bike mechanic.
January 30, 200620 yr Author will the seals have worn because of the water that has got in or would they have been worn in the first place because al was fine before i flooded it. the water literally covered my bike
January 30, 200620 yr Drain the gearbox oil,then re-fill with petrol (2 stroke mix)the same ammount as you would put in if it was oil,start bike and run for a couple of minutes,drain and put in the cottect ammount of oil.I have done this a couple of times on my bikes,the advise was given by a proffesional bike mechanic. <{POST_SNAPBACK}> That is insane ! Unless you enjoy strapping explosives to your body of course.
January 30, 200620 yr this is mad, dont know whos right,... sounds like a good idea, but then starting the bike?. well if it works !!
January 30, 200620 yr Must have been a reply from an anti-GasGas owner. You'd have to flush out either one eventually anyway. At lease water has some lubricating propery to it. What takes oil off something the fastest? GAS ! Who knows what it will do to fibre clutch plates.
January 30, 200620 yr I think you may be mixing 2 different problems. If your waterpump seal goes, you will get coolant water in the tranny fluid. Your drowning is a separate issue. Get a jug of cheap dexron ATF. Fill, run til cloudy, drain repeat. If it still doesn't clear up then you may have a waterpump seal problem. When my seal went, it took 2 changes to clear things up. A drowning may take 5-10 oil changes.
January 30, 200620 yr Author ok cheers. someone told me to pour engine oil in to eventualy get rid of the water? is it easy to change the water pump seal and how do you do it? sorry for keep askin but im not very good with bikes
January 30, 200620 yr I use trans fluid in mine normally, but you can use whatever oil you want. I wrote another post on changing the seal a couple months back. You'll probably want to replace the pump shaft too as its most likely the cause of the seal going bad. Do a search or look back a few pages for 'cloudy oil' or 'waterpump' posts.
January 30, 200620 yr The advise about putting in petrol was from a very reliable source,I did it twice once when drowned and the other time the water pump seal had gone.The bike in question has obviously got the water in through the breathers when it was submerged in the beck.if you have any doubts just keep flushing with oil,but the advise was given in good faith to me.
January 30, 200620 yr Author ok Thanks alot for the advice. well i have bought some more gear box oil this afternoon so will try it once more and see how it goes. the oil which is in now is cloudy but not half as much as it was when i drownd it. but the gears are working fine so am i best just leaving it or could it cause more damage
January 30, 200620 yr You don't want to leave the water in there too long. If your good gear oil is expensive, use the ATF, its cheap and you might even like the clutch action better. Just flush again and make sure its getting better.
