July 8, 20206 yr Can anyone help, building a Trifield but not sure what swinging arm to use. The frame is 1958 but the existing swinging arm will only allow a 17inch rear wheel. Any ideas! And does anyone have one. Thanks JOJOTUT
July 8, 20206 yr built trifield useing a james oval swingarm just doing a velofield with a widened 3ta arm that has been widened
July 8, 20206 yr Author Thanks Would a 3ta arm do if its modified they are a lot cheaper than an RE one
July 8, 20206 yr 1 hour ago, jojotut said: Thanks Would a 3ta arm do if its modified they are a lot cheaper than an RE one the 3ta was already in the frame when got it it has been widened by about 1 inch the frame had a b 40 engine before i bought it so i left it alone
July 11, 20206 yr i think royal enfield swingarm easier to get , you sometime need to wait on ebay for right affordable parts ? what is tyre you are planning to put 4.0 x 18 ?
July 14, 20206 yr Author Yep a 18inch rear wheel, just after anything that will fit or can be modified. Thanks
