jojotut Posted July 8, 2020 Share Posted July 8, 2020 Can anyone help, building a Trifield but not sure what swinging arm to use. The frame is 1958 but the existing swinging arm will only allow a 17inch rear wheel. Any ideas! And does anyone have one. Thanks JOJOTUT Quote Link to comment Share on other sites More sharing options...
wiggy Posted July 8, 2020 Share Posted July 8, 2020 built trifield useing a james oval swingarm just doing a velofield with a widened 3ta arm that has been widened Quote Link to comment Share on other sites More sharing options...
jojotut Posted July 8, 2020 Author Share Posted July 8, 2020 Thanks Would a 3ta arm do if its modified they are a lot cheaper than an RE one Quote Link to comment Share on other sites More sharing options...
wiggy Posted July 8, 2020 Share Posted July 8, 2020 1 hour ago, jojotut said: Thanks Would a 3ta arm do if its modified they are a lot cheaper than an RE one the 3ta was already in the frame when got it it has been widened by about 1 inch the frame had a b 40 engine before i bought it so i left it alone Quote Link to comment Share on other sites More sharing options...
Prototype Posted July 11, 2020 Share Posted July 11, 2020 i think royal enfield swingarm easier to get , you sometime need to wait on ebay for right affordable parts ? what is tyre you are planning to put 4.0 x 18 ? Quote Link to comment Share on other sites More sharing options...
jojotut Posted July 14, 2020 Author Share Posted July 14, 2020 Yep a 18inch rear wheel, just after anything that will fit or can be modified. Thanks Quote Link to comment Share on other sites More sharing options...
