October 13, 20206 yr Hi Guys. I’m getting to the end here I repaired my clutch basket got my kicker back in thank you for all the advice and help ! I notice a bunch of metal shavings from the end of that bolt that I used to lock the Crank and I want to flush the crank case cab or should I just pour in some diesel or parts cleaner , lift up the backend and it’ll flow out of that bolt hole on the front of the case , is that OK ? I’d rather not split the cases but I don’t want any metal getting in those bearings I assume there’s no liquid in the crankcase Other than fuel and two-stroke oil that comes in through the carburetter the only fluids I’m putting in the bike are in the gear case as far as I know. let me know if you have any thoughts on my questions if not I’ll proceed with the flush as best I can thanks as always Tarik
