November 4, 20206 yr Just purchased the above bike in bits. Can someone tell me where the ignition coil and the ignition unit should be mounted ? Also whats the switch thats mounted to the front number plate for, it has a rocker switch with the sign of a shower on it ? Edited November 4, 20206 yr by Vertematidog Year added
November 4, 20206 yr Hi if you remove fuel tank the coil and cdi box are next to the radiator filler spout. As for the switch it's a mapping switch to change ignition settings ... wet/dry..
November 4, 20206 yr Author Thank you Slack. The tanks not on it came in boxes ! Do you know how the cdi mounts at all ?
November 5, 20206 yr On my 2008s, the (Kokusan) CDI mounts under a wire tab on the left side of the frame near the steering stem.The coil mounts via a bolt into a threaded insert on the right side of the frame near the steering stem (near the rad cap). The voltage regulator mounts low in the area of the steering stem. And the fan controller mounts on the upper/left corner of the fan shroud. It's all a tight fit. Yes, the rocker switch is for the dual-mapping of the CDI. This may help: Edited November 5, 20206 yr by d2w
November 5, 20206 yr No worries. I can send some photos is you need more info. And note that it's possible that the actual wiring may be different than what's depicted in the schematic; in my bikes the rad thermostat is positioned between the fan controller and the fan. Hmmm ... this is actually less than optimal as the fan controller will always be powered. It might be better to ensure that the actual wiring is as the schematic shows.
November 8, 20206 yr OK, here are some photos. The first shows the ignition module (left) and coil (right), The second shows the voltage regulator (top, in the crescent cutout). And the third shows the fan control module (with the 'E') mounted to the fan shroud.
