Front light removal
Hi, I've just bought a second hand GasGas (2020 GP 300) and want to remove the front light to put a number board on.
I don't have a wiring diagram so I wanted any advice on how easy it is to remove safely without impacting any of the other electricals.
Thanks
Kirk
Kirk there is a plug on the headlight wires, just undo that and you are good to go.
You wont need it, but you can download the owner's manual, and the electrical schematic is on page 41.
as arnoux has said, cut the zip ties securing the light and follow the wire back into the loom at the headstock. you could remove the tank for clarity. Just pull the plug at the first connector and seal the connector with electrical grease.  Great bike the 300 GP.
