1992 Fantic 249 K-Roo Questions
Hey I have some questions, kind of a lot of them!
1. Do you put just straight distilled water in the 1992 Fantic 259 kroo, or can you put radiator fluid as well?
2. Is there a manual or a spec sheet available for general servicing?
3.  Does anyone know how many CC's they take of fork oil, ball park?
4. Where if anywhere can I get replacement cosmetic parts?
Sorry I know some of these questions have been asked by anyone who has purchased a Fantic but I can't seem to find any info anywhere. Thanks in advance!
If you run just distilled water it will boil up after about 15 mins, Iv use prestone pre mixed antifreeze in all my bikes with no problems. Most old 90,s forks use about 350ml of oil in each leg so start with 300 and you can always top it up if you feel the damping change dramatically when compressing the forks, it will usually be at the top of the stroke if you haven't got enough oil in.
