ossa mar original center case gasket thickness?
does anybody know the original thickness of the ossa mar central case gasket?....i want to know so i can get the correct -same thickness as original gasket ,in oerder to avoid shimming changes.......The old gasket seems to average at 0.025 inch   ive got a new one from vintco and it mic's at 0.030 inch ...
Sorry I have no  idea what an original unused gasket would measure up to, but I do have a cheap looking aftermarket MAR gasket ( not Vintco) here in blue card that measures .020 inch
Your   .030 inch gasket will crush down a small amount when assembled & all screws torqued up,
but the only way to see how much would be to - 1.assemble - 2. torque up screws 3. - dismantle - 4.  measure gasket
( then buy another Vintco gasket to use if you are happy with measurements )
If you say the old gasket   AVERAGES -.025 inch , then I wouldn't think you are far off
Are the tolerances that fine on an Ossa ?
I need to rebuild my own MAR engine soon, and I think I would rather have too much clearance rather than too little - better loose than something binding - I will be looking for a thicker gasket than the one I have
Artein gasket is .035 inch when new
