September 16, 20215 yr The frame number and engine number would have matched when the bike was produced so if you can't find a frame number on the headstock check the engine number against this chart which will tell you what you have. The only difference in the numbers is that the frame is prefixed B and the engine prefixed M http://ossa.2y.net/ossa/bilder/modelos/index.html
